rotating assy has arrived,off to the machine shop we go
Sorry, slugs by whom?Who’s stuff?
How is it going?
If you bought a balanced assembly the 4.070 piston will weigh more and throw off the original balance. You should press whomever screwed up to pay for a local balance job.Sorry, slugs by whom?
How is it going?
2nd set of pistons have arrived and to machine shop,the kit is from scat and they used the race tech/auto tech pistons,still not fully happy as i paid 218 for an expediete on the pistons which worked until the pistons came wrong and now behind a couple weeks,no mention of a refund on that as of yet.Sorry, slugs by whom?
How is it going?
Do you know what weight/gear ratio for the car and what kinda rpm he was turningWe did a 408 for my brother, only 10.2 on the comp and the duration is @ 50 254/256 and the it sounds good, but not that radical the big stroke definitely eats up the duration, iron heads pump gas on 10 inch tire, runs 11.00 in a 68 Dart
Yikes I hope it all pans out for you quick and painlessly. It can be so Frustrating sometimes.2nd set of pistons have arrived and to machine shop,the kit is from scat and they used the race tech/auto tech pistons,still not fully happy as i paid 218 for an expediete on the pistons which worked until the pistons came wrong and now behind a couple weeks,no mention of a refund on that as of yet.
Yea no doubt. Hydraulic, Solid, or Roller?Do you know what weight/gear ratio for the car and what kinda rpm he was turning
I wouldn’t get too excited about a little extra ring gap. I did that putting together a 440 and it still leak tested, less than 5 percent, 2 years later.slow progress,got the crank in and most of the rings filed for the pistons,got a little carried away with a couple so waiting for a single set
I was tempted but the one was like 28thou and goal was 18-20 so i was a bit leery to do it,i'm behind schedule since the pistons i said whats a few more daysI wouldn’t get too excited about a little extra ring gap. I did that putting together a 440 and it still leak tested, less than 5 percent, 2 years later.
