Interesting. I also have some X heads on a 68 340 but it had been played with by the time I got it (about 14 years ago) and no idea if the springs were factory installed, I highly doubt it. Also the rockers on it, no idea if they were the original. So these notches allow the rockers to clear the larger diameter springs but also allow better rocker oiling? When you say 'bearings' do you mean the load bearing area of the rockers on the shaft? As it is just smooth metal to metal there. Would you by any chance have any photos of those rockers, as I have had 3 x 340s over the years and would like to look through my rockers to see if I can see any of them there. They are all mixed up now, 273, 318, 360 etc ! Thanks
