IMO, (Build dependent) that is way to much head to be bothered with. You'll need to turn high RPM to even think about getting there worth at a min.
Better of with the stock 318 head with valve work, back cut and comp valve job. If you plan on a med. size cam,, the head would do well with a 1.60 exhaust, maybe a 1.88 intake valve. Again, build dependent.
