ron69
Member
I'm Still Having Problem Starting My Car I've Put New Time Chain In Check Compresion Very Low Cylinder 1, 3,5, 6. Any Help=p~
did you check comp before changing the chain?is it getting spark?I'm Still Having Problem Starting My Car I've Put New Time Chain In Check Compresion Very Low Cylinder 1, 3,5, 6. Any Help=p~
is it getting spark?how low is the cylinder pressure?i did check compresion before we change the timing we still had low compresion
cylinder started out at 25 then when to 45 got as high as 75. mybe the heads could a little work
thank you now i can drive it and have fun!!!!!!!!!!!!!!!!!!!!
got the car out drove runs great dam it's good to have a mopar
