BJR Racing
Cast pistons will take that much NOS.
Well I got it back together and then the rain came, so maybe tomorrow I'll get it fired up. Unless it quits here shortly, if it does I'll here the sweet sound of music.
Yep and this is just another option, and the journals will both be std. Good point Adam.
Dang man you dont mess around.........you made really good time on it.
Did you Pull the engine or do it in the car?? I assume you pulled it.
Do you have enough clearance between the bottom of the piston and the crank throws at bottom of the stroke. I rember this done on a 360 using low compression 340 pistons, (371CI) they had to machine some material from the piston bottom below the pin boss for crank clearance. Than there is getting it all to ballance.
I've had good luck with .030 over 360 and price is low.
No I did it in the car, when it broke on Thursday we had it apart in about 45 min.. I'm using a rear sump pan so it made it easy to get the pan down. This is in my race car so it's very accessable. Everything can be had by air wrench.
WooHoo, The rain has stopped so lets get it fired.
Hopefully Friday night I'll make some test runs, we have a 40% chance of rain as of now. But hey that means that we have a 60% chance that it won't rain.
