360-1 indy cylinder heads clearance issues
rrvolare
19Swinger69
Michigan
1969 Dart ... smallblock.
Anyone out there have any issues after installing these heads and intake ... as far as header fitment and hood interference ... I have the GERST suspension installed ...
1. What headers did you use from TTI?
2. Did you have to change to a different intake other than Indy's single plane to correct any hood interference ?
Thanks ...
Can't help you with the headers as my k is a factory piece. It's not uncommon to mill the carb deck on the Indy intake to gain hood clearance.
Justin... how much did you mill it down ? Did you headers fit with factory k-fram
Don't quote me but seem to remember other threads re: this using a 1/2" mill and a drop air cleaner base. Also believe the TTI step headers were used with a little massaging. I would recommend contacting both TTI & Indy for their suggestions. GL.
