since both are externally balanced will their torque convertors interchange????? i'm putting together a stock 400 , will have plain ole B B 727. ????
I am almost 100% certain no.
Also another tidbit. Not all 400s were externally balanced, as some had steel cranks.
I believe that there is a different amount of weight in a different location between the two. If the converter is good the easiest solution is to knock off the weights and use the proper B & M flex plate. From recollection they are not terribly expensive.
when I put a cast crank 400 together the balanced flexplate was indeed different than 360 balanced flexplate. B&M offers both. Imho it's easier to deal with than balanced converters when later changing engines or converters.
I agree easier. I have decades ago used the mopar weights that are welded to the convertor. who knows ,...I might find a good 400 trans/convertor!!!
bad part is I buy parts NOW I have thrown away decades ago!! not to mention see people restoring cars that back then were not even considered "parts" cars!!! lol
