We have 2 boosted small blocks. A 340 which has a worn out 6v-71 (a little shorter than a 6-71). Home ported iron heads, 8-1,
[email protected]. .540/.560@110lca. The blower is adapted to a single 4 barrel intake. Ive had it blown since the mid 80's. In a 3880lb Volare it'll run 11.0@122 in street trim @12psi. Ran it with a stock block for years. Then had a chance to get a R3 block which is currently in it. How hard can you run a stock 360 block and crank? We had one turbocharged. Ran up to 22psi. Never hurt the block or crank. We did eventually melt one piston after about 8 years. It ran as quick as 9.55@142 3750lbs. The best tuning tip I can give is be conservative with timing. We run 21-30 total depending on boost.
Doug
