racerkilla
So I'm putting together a 360 just to run around the area for my duster
Car is a 4 speed with 3.55 rear
Block is .40 over
Trw flat top forged pistons, stock re sized rods/arp bolts. All weight matched.
Crank is casting 4027169. Just had it turned to clean it up
Clevite 77 bearings.
Heads are 915 casting 2.02/1.6. Port matched and Cleaned up some(minor porting and polishing). New springs/locks/retainers. Checked out at 69cc. Will be running mopar performance thin head gaskets.
Intake is a 6 pack set up.
The main thing is what cam. I am thinking a Voodoo 268 cam?
Advertised Duration (Int/Exh): 268/276
Duration @ .050 (Int/Exh): 226/234
Gross Valve Lift (Int/Exh): .494/.513
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1800-6200
So what do you guys think about this set up? Any suggestions on other cams. My dad is stuck on purple cam but been reading that is old tech. I know the 2 purple cams I have in my other 340's run good.
Block is .40 over
LSA/ICL: 110/106
