73-340 Well-Known Member Joined Apr 3, 2010 Messages 153 Reaction score 0 Location Delavan,il Sep 8, 2010 #1 will a 360 weighted converter work behind a castcrank 340?
70aarcuda Master Hoader of SBM Legendary Member Joined Jan 16, 2005 Messages 16,639 Reaction score 5,967 Location las vegas Sep 8, 2010 #2 NO....there is a difference in the balancing... B&M list two different flexplates for those engines...
73-340 Well-Known Member Joined Apr 3, 2010 Messages 153 Reaction score 0 Location Delavan,il Sep 8, 2010 #3 i wasn't sure . a buddy of mine has a 3000 fairbanks converter i can have , so thought i would ask.
70aarcuda Master Hoader of SBM Legendary Member Joined Jan 16, 2005 Messages 16,639 Reaction score 5,967 Location las vegas Sep 8, 2010 #4 you can knock the weights off the converter...or use any unweighted converter with the correct b&m flexplate... or you can find the correct weights for the 340 cast crank...and knock the old weights off and weld the new weights on....or.......
73-340 Well-Known Member Joined Apr 3, 2010 Messages 153 Reaction score 0 Location Delavan,il Sep 8, 2010 #5 i guess you could say i got options
