I have a remanufactured 360 (by pros ~4-5 yrs ago) with a 2-row 22" rad with twin electric fans (not sure cfm), 180 stat, 16 psi cap, after initial warm-up temp holds around 190, if run hwy speed @ 85F, wants to settle around 205 or so. My first and main concern is that when drained weak coolant I only got about 6 qts (excluding heater core) and it only took about 7+ qts when I refilled. The system should have taken about 15 qts unless I'm missing something basic. If the system is clogged, I would expect it boil over, or does it need a 4-way bypass? I've been reading other posts and probably need to do a flush of some kind, but if really half plugged up, sounds major ](*,)
