I tried to install my 360 into my 72 Dart this evening. I have a Milidon 8 qt. oil pan [ 30940] on it,and I cant seem to get it to clear the k frame is it a really close fit?.I also need some help with motor mounts. Does anyone have any photos of correctly installed motor mounts.I bought a mt. kit from trans dapt. to go from a 318 to the 360.I have new rubber mounts to go on frame,one thick one and 1 thin one. Which goes where?I thought I had it figured out by looking in a mopar engine overhaul book,but I guess I didnt. I still have the original 318 mounts as well,and I messed with those a little as I have heard you can use them with one side using a small spacer. I also attempted to put headers in engine bay, tie them back out of the way,but ended up pulling them out as well.
