Mopar 360 engine. 30 over Diamond forged pistons 10:1 comp Moly rings.Factory rods resized with ARP rod bolts.Crank is 10/10.Windage tray oil pan is baffled with HV oil pump.Comp Cams Extreme energy 284 camshaft .Cloyes double roller timing chain. Edelbrock aluminum heads.Comp Cam roller rockers. Edelbrock performer RPM air gap intake.Holley 750 DP 4 corner idle carb. Electronic distributor. Super low milage 3500.00 located near Toronto Ontario Canada
