360 Flywheel Torque Question
RichardJ916
Howell Michigan
I will be installing a ballanced flywheel between the crank and 4 speed clutch.
I need to know what I should torque the bolts to on both ends.
Thanks
55 ft/lb on the flywheel to crank bolts
pressure plate to flywheel:
200 inch/lb for 5/16 bolts
30 ft/lb for 3/8 bolts
Are't there 6 bolts that hold the flywheel to Crank and 6 for flywheel to clutch.
55ft/lb on Crank side
30ft/lb on Clutch side
is this what you are saying
what is the 200inch/lb 5/16 bolts.....
I dont understand
Yes six bolts on the crank and six on the pressure plate.
If the pressure plate uses 5/16" bolts on it the torque spec is 200 inch/lb which equals about 16.6 ft/lbs.
