360 going in
Robbie2734
Lambcharger
Milford NJ
It's finally in the car, I'm beat! Now on to the aux stuff. It took a long time getting this far.
You are further than I. I wish ta 'ell I'd never taken mine apart.
That's how mine looked this morning...only I'm traveling in the other direction :banghead:
nice, magnum motor, what intake are you running ? 360 or 318 ?
Guessing by the flexplate, it is a roller LA 360 short block with magnum heads.
Yep, 90 roller motor with new magnum heads and a Bullet racing cams roller cam. Some work done on the heads, nothing over the top. I torqued the heads to 60lbs today and will torque them later on in the week. I'm using a Mopar M1 dual plane manifold. Here's a few more pics with some pieces on, it's finally coming together.
I prelubed it yesterday, forgot to put the oil pressure sender in. It does have oil pressure! I'm waiting for a new water pump and fuel line. The rockers are rough adjusted and I used a new mini starter.
We almost ran out of fuel, disaster!
