74dusterman
74dusterman
I bought a 360 that was rebuilt about 5000 miles ago. I pulled the heads off to do some porting and a cam change and found 2 different casting numbers. One is 3418915-A and the other is 4343475-A. Are these heads the same as far as flow numbers? Are they the same cc? They both have 1.88 and 1.60 valves and the ports look the same. Just wondering if it will is alright to run them or should I find another 3418915 casting to match?
