[FOR SALE] 360 heads
1973dartswinger
Got a set of 73 360 la heads. Included is a bin of the rockers lifter valves springs and everything off them. Also the camshaft that was running in the engine. Unknown specs. Motor ran but the heads needed work, ended up using the block to build a stroker with trick flow heads.
$150 for everything or best offer. Local pick up in Staten Island or Brooklyn. Ny. Too heavy to ship. Thank you.
