Ben Drinkin
Hey bartender!
326 HP.. And I'm sticking to it!
Update, the cam is around .480lift and 220 or so duration. Tried to edit it to the original post...but it wouldn't let me. Thanks.
That's a LOT bigger than a stock 340/360 cam.
No idea on cam. Only know rough numbers. The engine builder and efi guys needed to rough input so they can help me set it up. I think I'm going to break it in on a trusty 750 and then after break in go to the EFI. Don't need to wipe a cam screwing with EFI.
All,326 HP.. And I'm sticking to it!
Smog heads with 2.02 intakes cut in and no port or clean up work=as low as 201 cfm without a deep 70 throat cut, then the rest of the restrictive stuff... 315-330hp around 6k
The machinist said he's not just going to cut the heads for 2.02. Said that's sort of a waste at this point. Said he will cut down below the seat as well as the 2.02's. for what that's worth.Smog heads with 2.02 intakes cut in and no port or clean up work=as low as 201 cfm without a deep 70 throat cut, then the rest of the restrictive stuff... 315-330hp around 6k
Bad Robby, bad Robby!139.4 HP and 112.6 LB FT
WITH nitrous.
