You guys have given me some good stuff to think of and check out. Alignment, alignment, alignment - I think thats where I went wrong... but maybe its a burr on the spline (tranny shaft).... or lack of prime?
I did not prime the cylinders with motor oil first. Could it be that simple to solve? I applied alot of assembly lube to the cylinders when I was building so I figured it good enough...
I suppose its worth trying before I start ripping stuff apart.
Darn thing LOOKS like it's flush, or nearly so
Well I took it apart yesterday and examined everything... and came up empty. Everything looks fine! As crazy as it sounds I was really hoping to find something bent or broken, or at least some evidence of wear/rubbing somewhere. I'm uploading a couple of pics but theres not much to look at really...
There was a couple of burrs on the spline shaft, which I filed. The burrs were probably caused when I was installing. But I'm fairly confident everything went together, with shaft going thru disk and into pilot bushing, so I really don't know what was wrong. I'm putting it back together today, so any suggestions or advice are more than welcome!
PS - I measured all distances and tolerances over and over. Everything should fit.
Your pilot bushing needs to be pushed in flush!!!
TXDart
Then you are good !!!the picture may not show it very well but the pilot bushing is pushed in flush (actually its pushed in about 1/8" beyond flush)
One thing you need to CAREFULLY measure is the distance from the bell face to the bottom of the pilot hole, compared to the distance from the tip of the input shaft to the bell face of the gearbox.
If by chance you have an "auto" crank the pilot cavity may not be deep enough.
