dusterglenn
Digging through my bolt bucket, I realized I'm not sure the correct length the intake bolts should be. I assume they'll have a pilot tip and a captured washer.
I measured the hole depth on each one of mine and put in longest bolt it would take with out bottoming out.
It looked like the front two bolts should be longer, as the intake flange is thicker there. At least on the cast iron manifold I'm going to use.
Thanks guys!
Some holes are through holes with no bottom.... :bootysha:
Then I use an Adjustable length bolt:blob:
How do those work? #-o
I've always used hole thread lengthener instead....
