360 Intake with a quadajet carb.
Snake
Mopar Nut
Belleville Canada
Thinking of buying the 360 police intake,with the egr witch i need due to emissions,the intake has a quadajet carb,now i have always had Holley,so my question,how good is that quad is it easy to set up.The carb has all the ports need for emissions.
They are about equal to learn and tune as a Thermoquad.
Thanks RRR,66fs, info is what i need, going to build a low buck 360,the intake,card combo is only 35,Canadian.I think with the help of fabo we can build a killer.
First get the number from the side upright. I'll check on "first cut" jetting for HP Mopar small block. I saw it around here somewhere, did one years ago for the 273.
I love a Qjet carb, 389K miles on my DD with only one rebuild, works like a champ, small primarys and large secondaries plus as of a few years ago it never failed an emissions test, dont have to have that done now due to its a 1985. Mine is bone stock factory settings with a big K&N air filter, they like lots of air.
Primary Jets: 76
Primary Rods: 45B
Secondary Rods: BA
Also "adjust" the air bleed tubes to 1" from the bottom of the air horn.
