360 kevco pan hitting drag link and pitman arm with headers no steering
Suspension, Steering and Chassis
  1. 70Roadkill
    70Roadkill Well-Known Member
    568
    82
    Apr 2, 2017
    Dexter
    Local Time:
    3:42 AM
    so I installed a 360 into my 70 swinger. It was a 318 car. Installed a kevco pan and I don’t have steering with headers as the idler arm is hitting the header. I did also install 73 duster spindle and disc brakes. But kept my idler, pitman, and drag link. I don’t have enough clearance. Do I need to change to different idler that sits down lower?
  2. 65wgn440
    65wgn440 Well-Known Member
    312
    152
    Aug 16, 2016
    Toledo, ohio
    Local Time:
    4:42 AM
    I have added spacers to raise engine and/or trans for similar problems in the past.
  3. brian6pac
    brian6pac Well-Known Member
    4,886
    3320
    Nov 15, 2016
    N.E.Ohio
    Local Time:
    3:42 AM
    I think schumacher makes spacers
  4. dano
    dano Evil Handy Man
    3,394
    1277
    Aug 22, 2005
    Gresham, Oregon
    Local Time:
    12:42 AM
    What mounts are you using i.e. solid, stock, Poly? That part of the pan is the stock stamping so it should clear. It looks like both your pitman and Idler are placing the steering link level. So either your mounts are messed up or you have the wrong pitman/idler combo. Was this all on the car when you had the 318?
    I just looked at my and my 340 with Kevco pan has about 2" plus of clearance between the link and the pan bottom.
  5. 70Roadkill
    568
    82
    Apr 2, 2017
    Dexter
    Local Time:
    3:42 AM
    I ordered new pitman and idler since my old ones were worn. Stock mounts. I’m have a couple shims I’m gonna life the engine up remove them and shim the pass side up, I did the driver side to clear the steering column. In a couple hours if it’s not raining out gonna shim some more
  6. Daves69
    Daves69 Well-Known Member
    5,195
    3393
    Feb 20, 2011
    WestOfChi
    Local Time:
    2:42 AM
    Just throwing this out there as the picture appears to show no trans attached. Is the engine on the angle where the trans will actually put it?
  7. DARTGAME
    DARTGAME SuPeRcHaRgEd
    857
    447
    Jan 20, 2005
    santa barbara,ca
    Local Time:
    8:42 AM
    With trans in place engine will sit off center link and headers will clear
