Bought a little oil squirter can so I could get some motor oil on the valve stems and seals, pushrods, lifters, rocker arms and shafts. Bought a Kobalt inch/lb torque wrench to torque the rocker shaft bolts. Both of my SnapOn torque wrenches are too big. But ever notice there is a rubber plug in the end of a torque wrench. I never thought about it. When I was pushing the torque wrench on the rear bolt on the driver's side, I popped that rubber plug out. I never thought about that happening either. That little plug bounces around like a super ball in the lifter galley until it finds a space down by the cam and oil pump shaft gears.
