Dodge74
$1500 OBO...Fresh early 70s 360 block:
Bored .060 over
Keith Black hypereutechnic pistons, zero deck height, 2-valve relief
Molly rings
New Milladon oil pan and pick-up tube
Clevite p-series rods, mains and cam bearings (rod and main bearings are .010 under)
Sealed Power oil pump
Comp Cams double roller chain
New Molly coated fuel pump ecentric
New Mopar timing cover
New water pump (8-blade, heavy duty cooling)
Fel Pro gaskets
Comp Cams camshaft (XE262H) with 1.6 rockers will give just over .500 lift, RPM range for this cam is 1300-5600.
New Sealed Power lifters
New B&M flexplate (SFI approved)
Mopar harmonic balancer
For an additional charge of $150, I will throw in some J-heads, slightly used OEM 1.5 shafts and rockers.
Engine has over $1800 invested. Asking 1500 or best offer.
Bored .060 over
Molly rings
Fel Pro gaskets
