mikedevore Well-Known Member Joined Jan 13, 2005 Messages 2,567 Reaction score 126 Location Oklahoma Sep 4, 2013 #1 Will the 360 LA oil pan fit on a 5.9 Magnum engine?
Blue Grey Duster Well-Known Member Joined Jan 24, 2009 Messages 493 Reaction score 77 Location Ohio Sep 4, 2013 #2 according to this Hot Rod article, the 360 La pan will work if you use the la 360 oil pan gasket, don't use the Magnum gasket. http://www.hotrod.com/techarticles/...block_mopar_engine/viewall.html#ixzz2E6OEwaVG It's near the end of the article, "Oil Pan Interchange". Hope this helps.
70aarcuda Master Hoader of SBM Legendary Member Joined Jan 16, 2005 Messages 16,639 Reaction score 5,969 Location las vegas Sep 4, 2013 #3 yes...use the LA gasket with the LA pan...
340duster Well-Known Member Joined Jun 3, 2004 Messages 852 Reaction score 40 Location AB, Canada Sep 4, 2013 #4 As others have said the magnum gasket will not work. It will leak on one side rail. Ask me how I know.
vitamindart Well-Known Member Joined Jun 11, 2010 Messages 1,496 Reaction score 610 Location Vernon,Wisconsin Sep 4, 2013 #5 340duster said: As others have said the magnum gasket will not work. It will leak on one side rail. Ask me how I know. Click to expand... yep, had to drop mine and put a little smutz on it to get it to seal.
mikedevore Well-Known Member Joined Jan 13, 2005 Messages 2,567 Reaction score 126 Location Oklahoma Sep 4, 2013 #6 Thanks, very good to know.
