Turner8396
Member
360 Magnum Mopar crate engine:
less than 500 miles
380 horsepower at 5300rpm
410ft-lbs at 4400rpm
Swirl port combustion chambered heads with 1.925 intake and 1.625 exhaust stainless steel valves
9.0:1 compression
288/292 duration, .501/.513 lift hydraulic roller cam
Single Plane M1 aluminum intake manifold
Dbl roller timing chain and gears
770 Holley street avenger carb
Holley 110gph mechanical fuel pump
Flow Kooler water pump
Milodon 8qt oil pan
March Serpentine Pullies
Power Master 80amp alternator
Accel 8.8mm Race wires
K&N air filter
Engine was in my 1970 Duster. Has under 500 miles. Runs strong and sounds great. Nice lopey cam. Asking $4500 Located in Ashland Ohio 44805
less than 500 miles
9.0:1 compression
Milodon 8qt oil pan
K&N air filter
