360 magnum engine
goldmember
Rating - 0%
0   0   0
I have a 360 magnum freshly rebuilt that needs a new home. This engine was a good running engine from my truck that has been honed,new speed pro moly rings,Clevite 77 main and rod bearings,crankshaft polished oil holes champered,Thin head gaskets(9.5 to1 comp)2.02/1.62 stainless valves,bowl and pushrod pinch ported heads,double roller timing set, Bullet hyd roller cam 226/234/.525 lift 110lsa@107ICL) New hyd roller lifters,upgrade valve springs,chomoly retainers,Car or truck oil pan(take your pick), China RPM intake,recurved electronic distributor. $2900.00. Upgrade to EQ heads add $1100.00 This combo in a 3500lb truck and 727 with a street converter and 3.73 gears runs low 12's. Contact me for any details. Items located in N Florida USA
To bad I don't have the money right now. This would have been great for my 72 dart.
