360 magnum in a 64 valiant ?
honested
pelzer s.c.
Has anyone ever put a96 -99 fuel injected 360 in a early a body and used the factory fuel injection if so can you post some pics I'm jusst thinking I have several of these engs and it would be cool to do . Probably would need some type of cowl hood for the intake to clear :finga:
Here's my 65 Dart with a 5.9. I used the wiring, ECU, fuse panel, and air box from the Dodge Dakota. I modified the stock engine mounts and the hood closes just fine.
honested . we are building a 5.2 magnum 44re overdrive trans 64 Dart right now. We have built fuel injected magnum swaps since 98 . Its a great swap for the early a body, great power, mileage and a sweet cruiser with overdrive and 4 wheel disks.
What type manifolds or headers are you using ? are you building a new tunnal to run the 44e trans? do you have any pics thanks eddie
