i have a 408 magnum and want to check valve lash.it has comp magnum roller rockers.its a running engine.do i hand turn crank until its on the base of the cam and tighten while turning pushrods until i feel a slight resistance? then tighten another 1/4-1/2 or full turn?its a hyd.roller cam.i know the stock rockers u just torqued to 21 ft lbs,but i am not sure with the comp.adjustable roller rockers.please advise on the procedure.thanks
