360 magnum
All 360 Magnums are external balance. Your year should come with the balance weight on the flex plate so you would use a neutral balance converter.
Send Sireland 67 a PM, or comb through his posts. He has an answer, possibly in the Magnum engines thread. Smart guy.
the 360 mags are a different weight then the 360 la blocks. All 360 mags were balanced the same, so you could see if there is a flywheel for a ram with a 360 from the same time and that should work.
Excellent insight. To the O. P. ? Are we installing a A - 833 4 speed Mopar trans, a 'TKO/Doug Nash five speed/T5 ? Inquiring minds, need more information.
many thanks have 68 notch 360 auto now change to 4 spd always had 4 to row
Sireland 67, is the go to guy. P.M. him, or use the search function/search Magnum engines, forum.
