Making 300+ with a 360 is easy.
65-73 is a pretty big margin to be playing with... 65 on one side 73 on the other. It's not hard to check things out and see where you are.
Doesn't require fancy tools. As simple as a medicine syringes for kids from your local pharmacy and a flat piece of plastic with a hole in it.
Get a large syringe, like a 50 CC if they have one and a 10 or 5 cc one. Don't forget the cup of water.
Go for it. Nothing better than firing up and engine you built for the first time, except maybe the first drive after breaking it in to find out what its got.I looked down the 408 stroker rabbit hole and backed out pretty quickly. I think if I ever do one of those, it'll be based on a 360 Magnum block with a roller cam. For now, the 50 year old factory stuff will be a lot of fun. The other thing is, I'm pushing 60 years old and have never built an engine. I figured refreshing an old 360 LA motor would be a good first build.
@273 has posted a good video where you can copy what you see.I just picked up a project 360 engine this past weekend. It's a 1974 block out of a van and it came with a pair of 915 casting heads. One is a J head but the other is a U head. My understanding is they are basically the same head, can I use these on the same engine or should I start looking for either a J or a U head to have a matching pair. The bores seem really nice so my plan was to maybe take it to the local machine shop for a good cleaning, and hopefully only a hone. I was planning on using the Edelbrock Performer that's on a 318 in my Dart right now and also use the Holley 4160 600 cfm carb that's on that manifold. A good fairly mild cam and I should have a cheap but fun engine. My main question is the heads, though. Will a J head and a U head work well on the same engine?
Yeah like with a dead cylinder.Making 300+ with a 360 is easy.
If you only have one cylinder head, it would make it tougher. LOLYeah like with a dead cylinder.
.....and yet when you say "300HP" people shrug it off. .......and those are the ones who've never felt an honest 300HP in a car capable of putting every bit of it to the ground. It's a fun place to be in a light street car.If you only have one cylinder head, it would make it tougher. LOL
I like that youtube 273 posted up. The 360 with a mild cam, 4 barrel and headers will make 300 hp all day long. The XE250H is similar in lift and dur at .050 as a 340 cam. Close... I think comp says that 250H cam ranges to about 4800 and this one pulled a little past that point.
Put a larger cam in it like a 268 voodoo or XE268 and it will make a bit more ponies... and still be easier to tune and drive on the street. Even with a stock converter. Notice how tight the TQ was at the bottom of the pull, you'll never notice that difference.
As the guy pointed out with headers, the benefit isn't necessarily peak delta, it's the improvement throughout the range. The delta in the 2500-3500 area means the vehicle accelerates faster, plus when tuned correctly MPG increases with headers from that efficiency.
And that youtube also supports my contention that the old 340 dyno derby build with stock heads/rockers, air gap, headers and a XE268h cam made 391hp... sure it did! This 360 with more cubed, touched up heads and closer to true 1.5 rockers didn't make that 391hp number. HMMMMM....
I used speed pro H405C pistons. Came out to 8.8 or so. They were $135.00 new from an e-Bay vendor. Very close to stock weight. It wouldn't have even needed balancing it was so close on the balancer. That was using 1971 heads with 66cc chambers and fel pro gasket.I appreciate all the input, differing opinions, and suggestions. Like I said, it's a first build...sort of a science project for my own enjoyment. I had some Christmas money from my wife so I ordered a dial bore gauge, a 100 ml burette (1 ml = 1 cc, sometimes metric makes a little sense), a stand for it, a plexiglass CC plate, and a set of cylinder head stands. I plan to strip the engine down to the block, start taking and recording some measurements, and I'll cc the heads. I spoke to my local auto machine shop and he said they can hot tank the block and heads, check the block and crank, bore it if necessary, and help me out with what I need to order for about $500.00. I'm sure if I need anything done to the heads, such as hardened valve seats or cut for bigger intake valves, that will be extra. I plan to use the existing cast crank with new bearings if everything checks out, put new pistons in it (KB or Sealed Power Hypereutectic), and use the stock rods, maybe with some upgraded rod bolts. I'm not sure about the cam yet, I'd like something with a somewhat lumpy idle. The intent is to use some headers I have and a full dual exhaust. I'll dial a lot of this stuff in with my local machine shop, they do a lot of performance engines and a lot of Mopar stuff. For the heads, I also got a porting abrasive kit to knock off some of the casting flash and maybe check out some YouTube videos on some very basic porting. I was also considering some stainless intake and exhaust valves. I hope to end up in the 9.0 to 9.5:1 compression ratio. I will probably also look at gasket matching the intake just because it's an intake I already have and may look at upgrading in the future so I figured it would be fun to play with this one a little bit.
Someone asked about auto/manual trans, rear end, gears, tire size, etc... I don't know about much of that yet. I picked up an A833 4-speed out of a '69 340 Dart and found a good bellhousing to go with it. I need a bunch more parts for the 4-speed conversion. I have a line on an 8-3/4 A-body rear end but haven't got it yet. If I can get my hands on that, it's an open rear but a friend has a sure grip with 3.55 gears he said he would sell me. My Dart is a 318 / 904 Torqueflite auto with a 7.25 rear end. My original plan was to reuse all of that until the 4-speed kind of fell in my lap and I found the 360 core. Then everything changed. Wheels and tire size seem like a way off decision at this point but I've always been a fan of regular old Cragar S/S rims, old school. Tire size will depend on what I can cram in the rear wheel wells. Fronts will be a bit skinnier. I like the original MM1 Bronze paint and may even put the black vinyl roof back on it, that could go either way.
For now, though, it's all about some rust repair and an engine/trans rebuild and swap. I hope it can look as good as some I've seen in this forum but I really just want a good, fun driver.
Any additional comments and suggestions are always appreciated. Once I get rolling, I'll start a new thread and upload some pictures as I go, maybe some of you can warn me before I screw something up.
