Howard1784
This motor has about 3K on it which was removed from my Duster. I replaced it with a crate motor and could use the space. All you have to do is put a 750 carb, wires/plugs and go. Nothing worng with it. I do have a convertor, but weights should be welded on it to avoid vibration. Blue crate is not for sale unless you pay for it's replacement.
1,500 for the motor and see the You Tube link to hear it run before pulled. I have photos, but need to send in e mail as files are too large.
http://www.youtube.com/user/howard1784#p/u/0/BUB3-TO-V9k
Motor Specs:
71-74 Dodge 360 ci
Cylinder head casting# 974 68cc combustion chamber 1.881" intake valves 1.600" exhaust valves
Pistons- Silvolite part# 1279-.040 cast with .050" dish
Final compression ratio- 8.4:1
Crankshaft ground .010" under on both rods and mains
Competition Cams cam&lifter kit part# CL20-224-4
.488" intake lift .491" exhaust lift
274' intake duration (230' duration @.050"lift), 286' exhaust duration (236' duration @ .050" lift)
Motor Specs:
71-74 Dodge 360 ci
