1 1964Barracuda Well-Known Member Joined Feb 14, 2021 Messages 56 Reaction score 20 Location Northeast Ohio May 26, 2023 #1 I have a '74 360 and am using a 90* oil filter adapter. I don't believe that I need or can use the oil filter adapter plate. I need a conformation from FABO gurus.
Jadaharabi FABO Gold Member FABO Gold Member Joined Jan 8, 2016 Messages 10,698 Reaction score 8,597 Location Peoria, Illinois May 26, 2023 #2 Remove the flat plate.
Jadaharabi FABO Gold Member FABO Gold Member Joined Jan 8, 2016 Messages 10,698 Reaction score 8,597 Location Peoria, Illinois May 26, 2023 #3 If you do reuse it later. Drill the holes to the next size and put an extra hole in between each one. Now deburr your 90° adapter before you use it. Jmho
