360 Oil Pans
krazykuda
How-To Section Editor
Orland Park, IL
What is the question? I can't tell without side by side comparison, that looks more like a 273/318/340 pan.
The 360 pan has a much smaller REAR cutout than the front. 'teen pan the front / rear cutouts are pretty much the same size.
We ARE talking about LA here and not Magnum, right?
Here's the rear cutouts, again, the 360 is SMALLER The last bolt holes are all in the same place, so you can compare between
Well that explains why I had so much trouble with the reusable rubber Mr. Gasket i bought, it must've been for the 318 / 340, it was way to big at the rear, finally cut it off and used rtv. Knock on wood, happy to say no leaks yet.
