360 performance help
I paid $50 at parts store, whats the difference between them and the $10 dollar ones on ebay?
Really the reliability. I like the older nors stuff from 80 and back. The new electronics just suck. I am lucky picked up a old ecu tester from a parts store that was closing. The new condesers have a 50/50 chance of failing usually hot, all made overseas now except for acell.
do you have the sock filter on your pick up tube ,could be half blocked it only takes 1 load of bad fuel to stop it up.
If you can find the old Standard Ignition LX101 in the red and white box, they are also pretty good.
Im using the chevy HEI with a 6 pin connector. I also tried running a ground wire from it to battery I thought problem was fixed but it isn't.
