CMcAllister
FOR SALE - 360 race short block
Block - early casting 72 DC - 4.040 bore - lifter bores bushed - Hardblok tall fill - extensive oil system mods, rocker shaft oiling retained - ARP main studs - interior surfaces smoothed
Crank - OE 3.58 cast 360 - 2.100 rod journals - deburred/polished - internally balanced - ATI balancer with Chevy bolt pattern (should go back to ATI for freshen) - Chevy pattern MSD crank trigger and pick up
Rods/pistons - Crower billet rods - stock length - Wiseco flat tops - .990 pins - reliefs for .650+ roller
Cam - Cam Dynamics/Direct Connection Super Stock .620/.640 roller - Crower solid body lifters
Pan - Pan is the old Moroso rear sump 360 race pan with kicked out sump, trap doors, scraper and screen. We extended the front half some to pick up some capacity.
This assembly was run for a few years, maybe 400 runs tops, and was taken apart, rings and bearings and looked at every winter. It has been stored away and not run for years.
Looking for $3700 for everything including some accessories not listed. Prefer for it to be picked up in the south central PA area. May be willing to sell the reciprocating assembly if someone wants the bare block. We have options.
PM for more info or pics. Thanks.
