360 Ready to install....Finally
HemiTM
Loganville, Georgia
We are finally ready to install the 360 in the 71 Dart
1973 360 .30 over
KB 191 @ 12 to 1
J heads 2.02 / 1.60
Zero decked
Ported, Polished all that good stuff
Gasket matched
273 Rockers 1.5
Comp XE285 HL (going to probably end up needing more cam)
Mopar M1 manifold
Holley 750
2 inch carb plate
Hooker 5204 headers
Mopar ECU and Distributor
Summit wires
Autolite AR51 plugs
Mopar mechanical fuel pump (Going to get the Carter Strip Super Series)
We will be firing this thing up this weekend. Video will follow.
Forgot to add a couple of things. It`s getting connected to a Hughes 3000 stall convertor, 904 and 8.75 with 742 case and 4.30`s on a spool. This should be fun.
