We did try that, didn't help. Thanks anyway.Have u tried dropping the oil pump drive gear in? That should help with the camshaft issue hitting the rear plug
Try warming up the gear to 200f if there's no burrs on either the cam snout or the gear. Your doing fine! Take your time, lots of lube and it'll all come together.We did try that, didn't help. Thanks anyway.
Thanks to everyone for the tips, I ended up shoving a rubber fuel line in between the distributor gear and the rear of the engine, that allowed me to get the timing chain on with a little lube and some whacks of my fist, no hammer. It's all on now, #1 TDC, gears are lined up dot to dot with a straight edge through the middle of the cam shaft and crank shaft.The end play is controlled by the retaining plate. Just slide the cam forward, and if you have to wedge a pry bar behind one of the cam bearing journals...
eyeball line up the keyway and slip the gear on the cam, then use the rounded washer and bolt to pull the gear on the rest of the way. That is by design a tight fit. So you can pull it on or use the oven to expand it and then try again. Don’t hammer it, and don’t file it to make it fit more loose.
It's aluminum, it welds up real easyscraping of the old gasket and grease inside and out. And, it's cracked.
Thanks, I'll do that. Dean's Tilleman in Okotoks has been my main source of used parts, but the engine is getting new parts.Definitely try D&W for anything the main local shops don't have, I've lived just up the hill from them for many years and they're always very helpful. Also feel free to add me to your list of locals to check with for other parts you need for your car.
