360 runs strange, lifters??
MopaR&D
Nerd Member
Augusta, GA
I've been trying to figure out a weird issue with the 360 in my D200 pickup for years. Basically what happens is on rapid decel or when free-revving it, when the revs fall it sounds and feels like it's not running on a few cylinders for a few seconds. Does it worse when it's cold. I went through the ignition and upgraded some things, no change. I thought it might be a phantom vacuum leak, I just installed an Edelbrock 2732 adapter plate to make sure the carb was fully sealing to the Performer intake but it still does it. I recently replaced the timing chain which was badly worn, definitely runs better but still has the same issue. I did notice that if I shut it off while it's running funky then go to restart it kinda sounds like a few cylinders don't have compression. All I can think of now is maybe some of the lifters are pumping down on decel? Idk how the heck that would work but I'm stumped. It does still have the original cam and lifters afaik, according to the odometer the truck has 133k miles on it (had 122k when I got it). Runs like a champ otherwise but this annoys the heck out of me and keeps me up at night lol.
Interesting… I have a similar issue on the 5.9 in my Barracuda. I am pretty sure it is due to collapsing lifters when revving past 4500 then decelerating. In my case it is my fault because I did the pushrod measurements wrong before ordering new Smith Bros. Pushrods…urgh…. So I used the stock ones which are a bit to long .
Your issue might just be dirty clogged lifters ? Take them apart and clean them .
That's a good idea, they can be removed through the cylinder head on an LA engine right?
yes.
i'm wracking my brain right now, because i want to say there's *some* aftermarket headgaskets that inhibit this but i'm coming up empty. but that's something you'd realize straight away.
It's about time for an oil change, I might dump some Marvel Mystery Oil in it and see what happens. The truck sat without running for 10+ years according to the seller when I bought it, might have some gunk in the lifters that never worked its way out.
I have some new valve cover gaskets to put in, I'll check if the new head gaskets I installed back when I put freshened heads on it block the lifters from being able to be removed. They were the standard Fel-Pros that come in the full engine gasket set, 8553PT is the part number??
If you had collapsing lifters, I would expect a noisy valvetrain that you would hear. Tap, tap, tap. Collapsing would be noisier than bleed down, tap/tap versus tick tick.
