UOP
Hello, I was wondering if any of you knew if there was a height difference in the magnum and la truck oil pans. The reason I'm asking is because I'm working on putting a 360 magnum in an 86 RX7 (please don't flame me) and I'm not very happy with the way the oil pan hangs below the cross member. A guy I met at a local meet said that the magnum truck pan hangs about an inch lower than the la, but I'm having a hard time confirming his story. Do any of you have an la truck pan you could measure to the lowest point? I would really appreciate it.
