ef8340
okay fellas im needing some ideas i spent the better part of yesterday timing and tuning my 360 in the dart and got it pretty close but it doesnt spin a tire unless you nail it in reverse is there something im missing here heres what im dealing with is
89 LA 360 roller motor [0.40 over unsure of piston types, double roller timing chain less than 500 miles since rebuild ,
unsure of cam size doesnt sound radical motor came out of a 89 Ramcharger 4x4 so im thinking a R.V. style cam
edelbrock 318/360 performer intake this isnt the R.P.M or air gap
edelbrock thunder series 650 carb manual choke [not hooked up but fixed open]
direct connection electronic distributor
mopar performance coil, M.P. chrome box, along with the right ballast box for this set up
advanced auto O.E.M fuel pump for a 70 340 [ if that matters]
904 torqueflight trans w high performance valve body unsure of stall on convertor B&M flexplate 10239
8 3/4 3:23 open
anybody running a similar set up if so what's your timing set up at
8 3/4 3:23 open
