Thinking of buying a '73 Duster 360/380 crate, 3:70 rear gear, built 904 with a 3800 stall
Since it's all ready installed, just drive it;
that 380 crate engine is pretty tame, and the 3.70s are an in-between gear, so it'll be fine..
Is it what I would build? No. But so what. You have the perfect opportunity here to find out what you do or do not like, and swapping convertors at a later date, is relatively painless.
The thing is this; in First gear, with street tires and no traction aid, that
380/3800/3.73 combo will spin the tires at WOT, all the way to shift rpm........... but it will probably do that with a 2800 as well.
Where the 3800 will earn it's keep is in second gear, at a roadspeed that would stall the 2800...... like say 38 mph.
Cruising in Second with 3.73s and 27s, might get you 2600 at zero slip. If you nail the gas with a 2800 she might flash to say 2900, and the engine is way off the cam, so to get into "Rapid Transit", you would need to downshift.
But with the 3800, she might flash to over 3800, no matter, and that puts your crate-engine right around peak torque. If you downshift into first at 38mph, the rpm will flash to maybe 5000...... and the tires will spin up, driving the rpm to well past the power peak and you will want to shift right back into Second. This is where the 3800 earns it's keep; Not on the starting line; unless you can figure out how to keep the tires from spinning.
The other thing is 38 mph with 3.55s,lol . In second gear, this is 2450@ zero slip. perfect for cruising around and sneaking up on Chevies. A quick downshift gets you 4100@ zero slip, say 4700 coupled, and ready to rock. Your roadgear will be 3.55 x 2.45=8.70. Whereas with 3.73s it will be 3.73 x 1.45=5.41
with the crate engine, the torque;
at 38mph/3.55s in First @4100 might be 440ftlbs, whereas
at 38mph/3.73s in Second @2900 might be 403ftlbs
Sounds not bad right?
Except with the above roadgears ;
the 3.55s get you 8.7 x 440=3828 ftlbs, whereas
the 3.73s get you 5.51 x 403=2221
Here is a case of less actually being more.
On the street TM (Torque Multiplication is King.)
But hang on;
I picked 38 mph for a reason, it illustrates my point. The advantage to 3.55s is not across the board at all roadspeeds. It only favors 3.55s, when the 3.73s are in the next higher gear. The advantage that 3.55s have will only be , until you gotta grab Second, then the advantage will go to 3.73s. However, that stinking 380 makes decent power all the way to 6000, which with 3.55s and 27s comes to ..... about 50mph in First gear.
AND
you can give the advantage back to the 3.73s with more stall. So, IMO, someone has given your combo some serious thought.
Dyno Results/Superflow 901/Tested at Westech
Mopar Performance 360 cid 380 hp rated
RPM TQ HP
2500 380.6 181
3000 402.9 230
3500 415.1 277
4000 437.8 333
4100 439.5 343
4500 437.1 375
5000 416.3 396
5400 398.6 409
5500 388.6 407
6000 343.9 395
