Yes, the chrome valve covers from Direct Connection had chrome bolts too. Brings back memories!Hello, I have a 67 383 & 68 440 that both came with the original chrome valve covers but the cover bolts are long gone. Should they not be chrome as well? If so who supplies them? Thank you for your time.
My factory '67 383S has normal valve cover bolts with studs at both ends of the bottom flange. They are unpainted except for maybe a random dab of turquoise paint here or there, I think the chrome valve covers were installed right after the engines were painted and still wet.Hello, I have a 67 383 & 68 440 that both came with the original chrome valve covers but the cover bolts are long gone. Should they not be chrome as well? If so who supplies them? Thank you for your time.
The new kits are zinc plated bolts.Direct connection Chrome plated bolts...vintage$$$
Yeah, think blue loctite would be better suited for those.Be careful with red loctite and small diameter fasteners. Almost permanent, might take a torch to remove the studs if you ever want to.
Yep, that stuff is like a welder in a tiny red tube!Be careful with red loctite and small diameter fasteners. Almost permanent, might take a torch to remove the studs if you ever want to.
Like these. I have 2 sets. I live in 1978. Sleep in water bed and still have a lava lampYes, the chrome valve covers from Direct Connection had chrome bolts too. Brings back memories!
