383- 671 cam question
tooslow
lockport, Il
68 Cuda
-Really nice and has a Ford 9 in 8 point cage already. Been really thinking hard about building a modern 360/426 stroker,then spraying it with a 150 kit , people love the 426 combo, . After reading/researching the modern blocks are thin , the consensus . I am using my stout 69 383 Block . 'Dyer' sells the complete 6-71 kit including the manifold. I have the budget , looking for 750hp , not crazy #,s . I want it drive able.
I am dropping the block off at the machine shop tomorrow
looking for build suggestions :
cam?
Heads?
Should I fill the block
girdle?
oil mods ?
all good
First off…. Have you ever driven an honest 500hp A-body??? Because 750hp with either will be tough to drive. IMO
Id vote the 360 based stroker with the spray. But honestly, i think it will be a handle by itself. If you but the right parts in it.
