William Cowger
Active Member
SORRY I DO NOT HAVE THE 2 SMALL BOLTS AND THICK WASHERS THAT ATTACH THE DRIVERS SIDE MOUNT TO THE FRONT OF THE ENGINE BLOCK, THEY ARE EASY TO FIND, THE BOLTS ARE THE SAME AS ANY BIG BLOCK CAMSHAFT ATTACHING BOLT. THE WASHERS WERE USED ON MOST 65 AND DOWN MOTOR MOUNTS.
383 A-BODY ENGINE MOUNTING PACKAGE. FOR A-BODY BIG BLOCK K-FRAME ONLY 1 NEW REPO,DRIVERS SIDE ENGINE MOUNTING BRACKET, ,POWDER COATED BLACK 1 ORIGINAL PASS SIDE ENGINE MOUNTING BRACKET,MEDIA BLASTED,POWDER COATED SATIN BLACK 1 NORS DRIVERS SIDE RUBBER MOTOR MOUNT INSULATOR 2465861 31-2270 REPUBLIC 1 NORS PASS SIDE RUBBER MOTOR MOUNT INSULATOR 2 THICK WASHERS 4 FINE THREAD MOUNTING BOLTS &DIMPLED LOCKING NUTS 4 FINE THREAD NUT CAPTURED WASHER( ATTACH THE INSULATOR TO THE MOUNT&K-FRAME) 1 LARGE THICK WASHER&COARSE NUT THAT ATTACH THE INSULATOR TO THE PASS MOUNT 1 LONG SERRATED COARSE BOLT&THICK WASHER THAT ATTACH THE PASS SIDE INSULATOR TO THE K-FRAME WILL FIT 1967 1968 1969 DODGE DART GTS 383 , PLYMOUTH '383 CUDA AND A FACTORY BIG BLOCK K-FRAME $275 mailed paypal,venmo,zelle,money order
