Need crank and water pump pulleys for 383- 400 non ac and non power steering
How much and where locatedI should still have a set. Kim
All I know is crank can be 2 grove and water pump single groveI have some pulleys as well, but need dimensions to make sure you are getting what you are after.
Car is non ac and non power steeringAll I know is crank can be 2 grove and water pump single grove
I will post pics today for you.Car is non ac and non power steering
CanadaHow much and where located
ThxFrom what I found online, you will need a double pulley on the crankshaft with a smaller diameter inner pulley and a single pulley for the alternator. Both of which I no longer have. Good luck with your search.
Depending on what year he is putting them into. KimFrom what I found online, you will need a double pulley on the crankshaft with a smaller diameter inner pulley and a single pulley for the alternator. Both of which I no longer have. Good luck with your search.
As long as matched set should workI will post pics today for you.
