1968 383 short block all machine work done with new parts and ready to assemble. .030 over with KB400 domed pistons, JE low tension rings, new full groove main bearings and new rod bearings. Rods reconditioned with new ARP rod bolts. Standard steel crank, polished. Reciprocating assembly balanced. Block has been zero decked for this combo. Open chamber heads will have compression in the 10.4 range and closed chamber in the 11.1 range. All I want is what I have in it. $1575.00 OBO
Located in middle Georgia. Local pickup.
