The build:
91-360 block, 3.79stroke billet steel crank, Platinum series I beam rods from 440 source, Diamond flat top forged pistons and file fit rings, Hv oil pump, Milodon 8qt pan and pickup, Performance products dampner, 308 heads 202/1625 SS valves, 3 angle bowl hogged P&P 64ccs, RB STX21 cam 254*@50 .555/520lift, RB 1.6/1.5 roller rocker assembly, crane cmoly PRs, Airgap intake, BG 750 mighty demon carb, MP aluminum valve covers, TTi headers and TTi 2 1/2" exhaust system, SMR 3500 9 1/2"TC, 727w/reverse manual vb, 8 3/4 w/4:30s w/26x10 slicks. 3350lbs w/driver.
What will/should it run @ 3200ft elevation & at sea level?
