[SOLD] 4 15x7 SBC Cragar S/S wheels & BFG TA tires
69_340_GTS
Torrington, CT
For Sale:
4 15”x7" Cragar S/S wheels, 5 x 4” bolt pattern (SBC), 4 1/8” backspacing, with mounted/balanced BFG Radial T/A tires, two 225/60-15 and two 235/60-15. Tires were made in 2009, so no “age” issues. Tires & wheels are really nice, almost new, no rust, damage, etc. Also have used and new 7/16-20 RH Cragar nuts, plus nice heavy custom-machined stainless steel lug nut washers, and a couple extra new center caps. These fit good on a ’69 Dart GTS with S/S rear springs but no other modifications. The picture of my car shows the ride height I have… if your Dart sits much lower you might have clearance issues. The tires were a very tight fit on the rear, and I found that a 1/8” spacer between the wheel and brake drum helped a lot to avoid rubbing on the inner wheelwell. $1000.00, open to offers. Probably won’t make sense to ship these, as UPS will be $250-$400, so local pickup would be great in Torrington, Ct. If you are interested, let me know!
Bill
