805moparkid
Slant and AFX Guy
what is ring bind and how much cam are you talking?
he means coil bind... and what cam you get decides which springs which in turn get installed due to the cam lol...
order a cam... figure out which springs you will need for your app... then set installed height using this...
coil bind + .050 + VALVE LIFT = Installed height...
and when i say valve lift i mean not what it says on the card for 1.5 rockers becasue they arn't 1.5... so get a dial gauge and record how far the retainer moves then you have valve lift...
